A few things to check.
- Set up your scan lists. Default will be regular non priority scan.
- Set a programmable button for Scan A start/stop.
- Set a programmable button for scan add/delete if you wish to edit scan list(s).
- Enable channels to the scan list(s). Under memory channel, zone operations, scan list.. select the number "1" to enable that particular channel to scan list 1.
After you have a few channels enabled, clone radio, hit the scan start stop. Radio will begin to scan selected channels on scan list 1.
