Factory reset for Unication G4?
ecarvalho
Anyone could advise on how to factory reset a phase 1 original Unication G4?
I plan on selling mine and wanted to make sure its a clean slate for the next owner.
Thank you in advance.
kinglou0
Good luck. I've been digging for an answer on this for months now.
Reflashing the firmware is the only answer I get. Hard to believe there isn't a reset procedure that doesn't require reflashing.
ecarvalho
Thanks.
What I will try is create a new profile with no systems and load it into the G4.
I don’t want to put myself on the hook to build someone a profile with probably a bunch of systems and TGIDs. People will always find a reason to complain because the seller programmed it. I have no intention to deal with picky people.
If there is no real reset procedure, I wanna thank you guys still for taking your time to reply. Thanks!
Sent from my iPhone using Tapatalk Pro
Uni1
Unication Representative
DFW Texas
Create a new code plug file in the PPS. C,C1 then select your model number from the list.
There is nothing to reset. Everything is stored in your programming file. Reflashing firmware does not erase your programming unless flashing to an older version.
ecarvalho
Thanks! That’s the plan. New and empty profile / codeplug.
ecarvalho
I know .. will see.
I’ve considered your feedback and lowered the price.
