Fatal Error 01/88 XPR4550
kwsanders
I was given an XPR4550 UHF recently but when I power it on it says fatal error 01/88. Will not connect to CPS. Found the possibility of boot strap loading firmware. All I have is the serial to USB cable. Best to use it as a paper weight? Recommendations? Thanks
n3obl
ØAES-1024
PA
I assume you have a front usb cable. TRBO does not use serial cables.
K2NEC
5F6
I was always under the impression that a fatal error was unfixable
belvdr
No longer interested in living
