fcc lic freq id and lcn
E5911
would the freq id for a group of frequencies i know to be a edacs system give me any clue to the lcn of that system?
frq freq id
000853.11250000 4
000856.93750000 1
this is a partial example
Radioman96p71
Polk County, IA
Nope, the two are mutually exclusive. The only way to figure out the LCN order would be to either run Unitrunker on the CC and watch when activity shows and on what LCN, then use a second receiver to browse the FCC licenses to try and find it. Or guess a lot and see if you can find it.
Best bet would be to try the database here, or post in the appropriate forum to see if anyone else has found out the order.
