FCC Menu and the 700P/Pi
TDR-94
Does the KRD version of the 700P/Pi have the same FCC Menu features as a P7100? I know the RU versions that I have seen do indeed have the same features in the FCC Menu as the P7100. Does anyone remember if the KRD version of the 700P/Pi supports the same FCC Menu? I can't find any info that's specific to the KRD version.
TDR-94
I guess this version of the 700P/Pi is too old for anyone to remember specifics about it.
Oh well.
ElroyJetson
I can only remember this much: The FCC menu requires certain versions of firmware to be operational. If the firmware doesn't support it, FCC menu will not work.
It's a handy tool when it does work. In conventional mode you get a pretty good RSSI/signal strength meter and in trunked mode you can see site activity as a percentage of system loading and site signal strength.
TDR-94
Do you remember if the FCC Menu has the Hz error readout in the Menu on the KRD 700P? I know it does on the RU 700P.
Would the KRD possibly need the SC4 FCC Menu file?
TDR-94
Just checked,the KRD version doesn't have the Hz error readout in the standard FCC Menu.The menu is pretty bare in comparison to the RU version or a P7100. I'm wondering if the sc4.FCC Menu file may have it.
TDR-94
Nope. The sc4.FCC Menu file didn't expand on the FCC Menu already available in the radio, like the sc5.FCC Menu file does for radios programmed with RPM. :(
On a side note,I can't get the Squelch adjustment to work. I have SQLCH assigned to a button and assigned in the conventional radio MENU,but it just bonks when selected or the button is pressed. I also have the squelch check box checked in Power Up Options and it makes no difference.Still doesn't work.
Did these KRD 700P/Pi's actually support the manual squelch adjustment feature? ProGrammer R18B Help indicates that it's supported for the 700P/Pi,but no mention of whether it may be specific to the KRD or RU.
TDR-94
Yes,it can only be used on conventional analog systems. It's functional on the P7100/5100,P7200,P7300,XG etc... It's functional on the 700P/Pi RU version. Doesn't function on the KRD. I was also checking other assignable functions and found that CMD MUTE and CG SEL don't function either on the KRD.
If those are assigned to the radio MENU or a function key and you select them,the radio just gives you the audible error bonk tone.
