FDNY TPS on APX8000XE
Radio5390
Long Island, NY
Good afternoon. I was wondering if anyone could tell me how to mimic the double TPS data burst on an APX8000XE similar to what the FDNY uses on their “HT” channels? I believe it has to do with the firefighter accountability system that they use. Can anyone provide any information on this or possibly photos from a code plug showing the correct way of setting it up?
Thanks.
Radio5390
Long Island, NY
Mine does not. My Motorola dealer had tried messing with one that did and could not mimic it. I had gotten my hands on an FDNY APX and can confirm that the 2 bursts do indeed originate from the radio and not an “on scene gateway” as some other forums have stated was a possibility. I believe the “FDNY TONE” flash code is their unique distress/man down alert.
ElroyJetson
Copsounds and Firesounds are only useful if your agency dictates their use. For literally EVERYBODY else, they are proof of a high level of whackerage and you WILL be pissing off whomever else has to share the frequency with you.
Be sure to wear your helmet when making your radio transmit Copsounds/Firesounds:
DON'T BE THAT GUY. EVERYBODY HATES HIM.
BFD319
NASSAU COUNTY,NY
Set up a conventional system to astro signal
set up a conventional personality and make the rx voice/signal type mixed mode, set tx voice/signal type astro, in signaling select your astro system you set up leave non astro as none, then click tactical public safety under the features
