FDNY VHF/UHF - Are both still active?
Ottawa, ON
#1
Hi,
I'm heading to NYC next week. I noticed in the FDNY Database that the new UHF Dispatch/Mobile split frequencies are listed as well as the older VHF Hi frequencies. My scanner (BC245XLT) is a bit older and will not split the UHF frequencies past .0005. Are the VHF Hi frequencies still in use/mixed with the UHF ones? Thanks.
NYC Metro
#4
Hi,
Even if your scanner doesn't go past .0005 you should still be able to hear the UHF.
