Fed activity?
gldavis
KE7MQF
Bountiful, UT
Receiving encrypted comms on 167.2125, 167.3375, and 167.4875. Same signal/traffic on all three channels. 167.3375 is the repeater out. I suspect 167.4875 is the input.
522
Murray, Utah
I must have missed it. Nothing on currently. Or at least that I'm hearing (or not hearing as it were)
522
Murray, Utah
I wasn't patient enough. Heard it coming in as well.
ecps92
Taxachusetts
What NAC ?
And I am guessing all key up at the same time ? Looks to me like a Vote-Scan or wide-area net
with an agency we typically see in the 167 band but [IMHO] the input is down in the 162-164 range, those are all repeaters
dlwtrunked
167.3375 and 167.4875 are almost certainly too close to be a repeater. They could be simulkeyed repeaters though. I would look around 162-165 area for inputs.
ecps92
Taxachusetts
Most of the Country that agency uses $167, but there are exceptions and [IMHO] those exceptions
are driven by near-by other Field Offices and the need to have a different NAC to eliminate interference.
IF you have DSD+ or other means, the user RIDS will likely begin as 348, which would confirm
the Salt Lake Field office.
Salt Lake Field Office coordinates 18 different RA [Resident Agencies] in the region. [3 states]
Based on monitoring it is likely there are 18 different "Wide Area" or "Vote-Scan" networks
for this FO, [18 radio zones of Repeaters - usually one Zone per RA] and then add a few
Stand Alone [Admin] and then the Interop and Nationwide Zones
And this one agency is generally NTIA compliant with the Repeaters being 167 and higher
the use of 167 Repeaters is likely an NTIA exemption for the Hoovers :)
NAC was/is 293 on all three.
gldavis
KE7MQF
Bountiful, UT
from my notes: rid=3481090/3485056/3485249/3485245/3481099(was not encrypted a couple weeks ago)/3481146/3481126/ and several others. I see a pattern developing.
("Hoovers". I like that. ;) )
jonwienke
More Info Coming Soon!
VA
ecps92
Taxachusetts
Yes it does :)
Yes there is no standard Off-set plan, but...
162.0500-166.4875 Mobile/repeater input
169.5125-173.2000 Base/repeater output
173.4000-173.9875 Base/repeater output
and of course there are exceptions/exemptions issued by the NTIA on a case-by-case basis
and from monitoring many 167.xxxx, 168.xxxx and 169.xxxx FBI Repeaters that use 162-165 mhz inputs, there must be many of them
That says nothing about repeater offsets other than there is no standard. But unless you're using TDMA and single-frequency repeat, you need more than 150KHz of offset to not desensitize the RX side of the repeater.
ecps92
Taxachusetts
Yes there is a pattern for "the Hoovers" RID assignments
jonwienke
VA
Yes it does :)
Which proves my point that there has to be more than 150KHz between input and output frequencies. That's indicating 3MHz or more. What's your point?
ecps92
Taxachusetts
Your statement was "That says nothing about repeater offsets" - when it totally discusses Repeater input/outputs aka Offsets ;)
enosjones
Price, Utah
Department of Justice
FBI - Salt Lake City
Frequency Input
License Type Tone Alpha Tag Description Mode Tag
167.33750 BM293 NACFBI SLC 1FBI Salt Lake City 1 P25 Federal
167.76250 BM293 NACFBI SLC 2FBI Salt Lake City 2 P25 Federal
167.96250 BM293 NACFBI SLC 3FBI Salt Lake City 3 P25 Federal
170.70000 BM293 NACFBI SLC 4FBI Salt Lake City 4 P25 Federal
170.72500 BM293 NACFBI SLC 5FBI Salt Lake City 5 P25 Federal
170.75000 BM293 NACFBI SLC 6FBI Salt Lake City 6 P25 Federal
Marshalls Service - Salt Lake City
Frequency Input
167.36250 RM293 NACUSMS SLCSalt Lake Operations P25 Federal
