Fed Heights
cristisphoto
Secondary channel MY bet....
MOst likely ther secondary or third etc
THis is common!!
Why I don't know, except in bigger towns, cities etc,
they have SOO much traffic that having just one channel woud be INSANE...
\And deadly.....
Crista
jfab
Broomfield/Aurora, CO
THis is common!!
\And deadly.....
Crista
Yeah. However they are not using their "primary"channel at all!
jfab
cristisphoto said:
Hmmmm that is intersting
Still common though!!
Maybe they are "tossing", things up a bit....
OR maybe dispatch just changes channel every once in a while
How busy is that channell??
Federal Heights PD is Conventional:
http://radioreference.com/modules.php?name=RR&ctid=241
Crista
They stay relativly busy for the size of the town. Negative. They switched to DTRS. I will change that right now!! Thanks for your help!
cristisphoto
Also>>>>
No problem
ALso FYI
look above the freq parts and there are a few EDACs systems as well
and about one Project 25
and about one LTR
Regards
Crista
jimmnn
Colorado
Crista
Suggest you program in and try that conventional freq, they have not been on UHF for over a year.
Jim<
luke-1
Parker, CO
Primary is probably on "emergency traffic only" in which case they would move new calls to channel 2.
Luke
scanlist
Greeley, CO
Just paging for the FD on 453.900. All Fire agencies dispatched by ADCOM are paged on their old conventional UHF's and VHF's out East.
If you program up the old PD channel 453.575 you will hear public works on it as they reassigned the channel to them.
Phil.
RISC777
jfab,
Their FD also flip flopped, so to say, their two freq.s also. So long as you have each ones two TRS IDs, you'll hear their traffic. The toning off of TRS is up to you.
jfab
RISC777 said:
jfab,
Sorry, but what is TRS??? Thanks!
