Federal Signal Informer IP receiver?
excapt5
MASSAPEQUA
Hi all, picked up a Federal Signal Informer model # EN- I-IP-IO receiver on ebay. Different from others that ive had as this is black and has no external antenna port? Cant find too much info on this, anyone using one?
Kevin
kb4mdz
Cary, NC
Try plugging in an ethernet cable and seeing if you can talk to it? Try one of the standard defaults, like 192.168.1.1 or such?
kf8yk
Download the programming manual here: Informer IP
Manual includes default IP address & login info as well as the factory reset procedure to clear out the current config.
a417
I feel the OP was looking for one to recieve tones over the air in RF form and activate items/alert, and instead bought one that requires a network connection to a host server.
IIRC the IP address for the device is 10.10.10.1 --> admin/fedsig
DisasterGuy
Maryland Shore
We have only played a little bit with one of these. If it's the model that I'm thinking of that informer model is network only and only is used for reporting contact closures and making contact closures to the Commander server.
a417
The "IP" in the model number gives it away.
