Feed Dropping
W9AJM
Wisconsin
I monitor me feed using both Web Player or WMP. It seems that after a period of computer inactivity, the received feed drops without any warning and you have to reconnect. This doesn't happen all the time. Anyone have any thoughts on this? Everything else seems normal.
rweinkauf
Pinckney, MI
I'm experiencing something similar with the feed I provide, if I understand your issue. I've been using ScannerCast and ever since the servers being down a few days ago my feed is really choppy, hangs, and cuts out when I monitor it at my workplace.
Tonight I connected up to a more powerful PC and supplied the feed from a machine with more horsepower- same thing.
I also just downloaded and installed RadioFeed as my broadcast software, and the feed is still choppy and hanging. I get better information from RadioFeed, and this is what the status window is showing me:
Source Client Log
07/11/11 20:58:10 - Source Client Connected To A RadioReference Server
07/11/11 20:58:40 - Source Client - RadioReference Timeout
07/11/11 20:58:40 - Source Client Disconnected
07/11/11 20:58:51 - Source Client Connected To A RadioReference Server
07/11/11 20:59:27 - Source Client - RadioReference Timeout
07/11/11 20:59:27 - Source Client Disconnected
07/11/11 20:59:38 - Source Client Started To Connect To A RadioReference Server
07/11/11 20:59:38 - Source Client Connected To A RadioReference Server
This kind of thing is making my feed totally unusable.
Does anyone have any suggestions? Feed behavior hasn't been effected by swapping out a PC or installing alternative broadcast software. The PC has no other apps running, no background streaming or other traffic other than the RadioFeed/ScannerCast function. My network speed is 19.30Mbps download and 2.09Mbps upload running on an N wireless network. That should be enough.
I think I'm up against the wall here and I'm out of ideas.
Rich, N8QLT
wa8pyr
Staff member
Lead Database Admin
Ohio
I've been getting exactly the same thing with the same kind of messages; I run my feeds from a Windows virtual machine on a Mac Mini, but it doesn't make any difference whether I boot to Windows or run it as a virtual machine. It will run fine for a few days, then start throwing errors like you note below.
I've also tried a straight Windows box (yes, I still have one.... which normally sits in the closet and does nothing) with no success.
Source Client Log
Rich, N8QLT
hatzolahCW
NY
yes i have now the same problem!! i just got approved for a feed and cant bring it up!! any suggestions????
W8RMH
Feed Provider Since 2012
On your feed page click on help and file a ticket. That will go right to an admin. You will have a better chance for assistance than hijacking a 2 and a half year old thread.
hatzolahCW
NY
i just changed the port from 80 to 8080 working like a charm thanks!!!
