Feed id's
WayneH
Forums Veteran
Super Moderator
Your master site
Well, for one, you want to post in the correct forum. I've moved your post to the Live Audio forum. Hopefully someone here can help you out.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Look up at the top of any RR page.
1. Click on Live Audio, select Live Audio Home
2. Then click on the state of interest (California)
3. Then select Riverside County
4. Then hover your mouse over the description of the feed you are interested in
The URL to that feed will be shown in your browser (usually at the bottom left if yo uare using Firefox).
There are at least two mentioning CAL Fire. Looks like the most popular one is feedId 19
Code:
CAL FIRE and Riverside County Fire
http://www.radioreference.com/apps/audio/?feedId=19
Mike
sbfdfire
So Cal
Hi Mike, I got the id and it is working, but i don't see them when I hover. Can multiple id's be inputting in my player?
mtindor
FMP24 PRO USER
Oh, you are talking about the Alpha Tags? If you are referring to the alpha tags that are supposed to be streaming with the feed, then you need to use a player such as Winamp or Itunes, which will display the tags as long as they are being broadcast by the feed provider.
Mike
richtidd
San Mateo, Ca
Hi MIke, where do I put the feedid for multiple agencies in one player?
If by "feed id's" are referring to the feed audio stream?
If so, & if you want to use one player to listen to several feeds you can.
Use Winamp, iTunes, ScannerLive, or ScnnerForce.
All are in the RR Live Audio Wiki section "Listening to Feeds": Live Audio - The RadioReference Wiki
If that is what you mean by "feed id's" please explain.
