What OS are you on sir?
streamripper http://connorm : pass@audio.broadcastify.com/1432.mp3
Connecting...
error -39 [HTTP:400 Bad Request]
bye...
shutting down
Windows 7 home premium 64 bit.
Connecting...
bye...
shutting down
Used for a home data project, sorting etc.
But it is also used in regards to active volunteering and bushfire alerts in WA, Australia.
I'm not sure I understand this. The RadioReference and Broadcastify user database are literally the exact same user credential database.I later found that I could open two simultaneous streams if I used my Broadcastify credentials for one stream and my Radioreference credentials for the second. I assumed that this was by design.
What exactly does that mean? I'm not able to glean how we can support your efforts there. Are you trying to setup some commercial service based on our archives / services? I attempted to lookup what you are doing based on your email address domain and that resolves to nothing. ???
I have noticed the same issue as the other posters. After using the new static URL sign in and pasting that URL into various players, I get either an access to audio.broadcastify.com was denied or 403 account already in use when trying to listen to "more than 2 of the same feeds". Definitely a concurrency restriction of some kind when using the static url sign.We don't have any login restrictions or restrictions on the amount of feeds or concurrent feeds you can listen to. I'm not sure what problem you are experiencing here.
OK, thanks for the report. I'm going to have a look today to see what might be happening here and see if I can recreate. Stay tuned.I have noticed the same issue as the other posters. After using the new static URL sign in and pasting that URL into various players, I get either an access to audio.broadcastify.com was denied or 403 account already in use when trying to listen to "more than 2 of the same feeds". Definitely a concurrency restriction of some kind when using the static url sign.
Thanks - but I'm specifically looking to make it work with Sonos. I'm familiar with how basic auth works in most clients, sadly Sonos does not properly parse/encode the user: pass format into an auth header. Hopefully someone from RR can chime in.i got it working with winamp with username : password,, no spaces but only one session at a time (had the other stream on chrome)
