Guys, I had a timed-on relay going to a SPST 30A relay to power my two radios and scanner in the truck. I set the timed relay to 5 seconds to eliminate any voltage ripple upon the motor starting from reaching the radios. Well the timer relay finally bit the dust after roughly 6 years of usage. Not bad for $45 I spent back then. Now I'm looking at Havis's Chargeguard and wondering what mode you guys are using. I'm more worried about voltage ripple while motor starting affecting the equipment than the timed shutdown. Should I use DC, AC , Ignition mode? Also, are you hooking your devices' grounds up to the ground on the Chargeguard or a seperate ground? Thanks.
