Could fiber optic cable be used to improve a received signal instead of using a copper media in coax? The receiver circuitry probably would not be compatible with a fiber optic signal huh?
Fiber optic cable is used to transmit light, not electricity.
Fiber optic cables can transmit digitized information, by carrying modulated light. They can't transmit "radio signals" per se, which are analog and in a different spectrum than the fiber is able to carry. You would need the information contained in the radio signal to be digitized and then use that data to modulate the light. Then reverse the process at the other end. No actual radio frequency energy would pass along the fiber.
You will also have a problem if you want to transmit on your new fiber optic antenna system. You can't, at least not with any appreciable power.
I'm nobody to argue because I know nothing about this stuff. But If what I am reading is correct and if I understand what I'm reading, RF analog can be transmitted by optic fiber (OF). Please correct me if I read it incorrectly. http://www.rfsolutions.com/fo-rf1.htm
