ProScan: Fill down utility
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
As usual I could be doing something wrong. Trying to use the "Fill Down" utility on a non_DMA scanner and not having any luck.
I'd like someone to open a database for a non-DMA model (like BC125AT), change the mod to AM and try to "Fill Down" on the "Mod" column and see if it works. It seems to me the the column can't be highlighted, but it could just be me doing something wrong. And I'd rather not someone just "tell me" how to do it, I'd like someone to actually try it.
If someone else can confirm this I'll send a bug report.
Whiskey3JMC
RTFF
Southeast PA 🇺🇸
Tried it with target model BC125AT and seeing the same. Have to switch mode to AM for 1st and 2nd row then drag to highlight the remainder of the column for the fill down to work. Running 23.5
Whiskey3JMC
RTFF
Southeast PA 🇺🇸
I tried it again just now with an external mouse. Was able to create my first AM entry, then highlight its cell and the rest of the column. Fill down worked that time
KevinC
Encryption
Super Moderator
Thanks. I always used an external mouse. I was just expecting to be able to highlight the column (at the name) like I can in DMA models as opposed to picking a row and mouse down. No big deal now since the way you originally posted works.
