Firefox Version 2.0 Beta Candidate Released
hotdjdave
K9DJW - Senior Member
"The Valley" (SFV), Los Angeles, CA
If it's anything like that "Bon Echo" beta (or whatever they called it), then I will wait for the final version.
I know it was a beta, but it messed up everthing for me. Thank goodness I saved my bookmarks in a file. I had to undelete and reinstall FF all over again. Now my FF does not work the same as it did. For example, when I first open FF, it does not open to the full maximized position, I have to maximize it. Also, I cannot choose anymore where my bookmarks go. I have to save the bookmark, then go into the bookmark utility an put it where I want it.
I uninstalled and reinstalled FF several times. I even removed all instances of FF from my registry. I still have the same problems; all caused by that FF "Bon Echo" beta. I will just have to wait when I do my yearly hard drive wipe and reinstall Windows to fix it.
brandon
SoCal
@hotdjdave
Did you try removing your Firefox profile as well? Go to start > run and type in %appdata%
Then rename or delete the Mozilla / Firefox folder and restart Firefox to create a new default profile.... then u can import your favs, etc...
I tried the 2.0 portable FF is there a changelog anywhere? I'll be sticking with 1.5 until 2.0 is final.
