Reading Banks (download) banks 0-8 worked very well yet could not write a single bank (uplosd)
Troll elsewhere fella, another new account writing nonsense.
There is no Butel software for the DV10, see the note on their webpage which reads:-
"AOR DV10: at this momemt there are no plans to develop software for DV10 because this seems to have very low priority at AOR. We suggest to look at alternatives from Uniden or Icom R30."
BuTel software: THE Radio Scanner Software for Uniden / Radioshack / Icom / AOR / GRE
Butel is skilled enough to know that the remote control is a broken mess, and for that reason they don't make software for it. That's what clever developers do.. nice troll attempt anyways.
TSCM software FFT receiver AOR AR2000 SR2200 Alpha AR-ALPHA AR5001D AR2300 AR2600 AR5000 AR8200 AR8600 SR2000 SR2000A AR6000 products programming software download spectrum monitoring
Opps it's should said " Butel ARC DV1 PRO works to read AOR DV10Reading Banks (download) banks 0-8 worked very well yet could not write a single bank (uplosd)
Please correct me if I'm way off base as I'm sorta noob-y in the fancy receiver dept... I don't have a bunch of fancy test equipment, but if I get an IQ I know how to twist it around in SDR#. Shouldn't I be able to tune in a standard FM Radio station? I'm in downtown SF and I get nothing but static on every one I've tried.
Most of the ARC DV1 Software virtual control works on the AOR DV10
Yes most work as long as it not a write to memoryHave you tried it?
My AOR DV10 is 800Hz off frequency after 4 hours 452Mhz
We sincerely hope that with the new features you will enjoy even more to monitor digital signals with the AR-DV10.
LOL
1. Remove the battery, wait for one minute, reinsert it and after bootup, try to redo the firmware update, followed by a system reset.
2. If that did not fix the problem, or if the keys don't respond, please use the PC update support tool. This procedure will just take you a minute.
Finally do a system reset.
Don’t hesitate to contact us again if needed.
Regards,
LOL
