Firmware for bcd536hp
buddrousa
NW Tenn
#4
I have and use over 20 scanners 5 BCD536's 1 SDS200 6 BCD996P2's 4 BCT15x's 1 TRX-2 1 PRO197
1-BCD436 1 SDS100 1 BCD325P2 1 BCT346XT 1 TRX-1
You were talking about a BCD536 and the new firmware sounds great on all 5
iMONITOR
MACOMB, MI.
#10
I’m using a portable speaker
Describe 'terrible'. Is it to much bass, too much treble? Digital simulcast 'robotic' distortion, breaking up? Not full quieting, static etc?
I took delivery on a new BCD536HP today, updated the firmware and it sounds awesome on a 12 site simulcast system with very clear audio. Do you have the speaker plugged into the back speaker jack, or up front in the earphone jack?
nj
#11
It’s breaking up and I have the speaker plugged into the back speaker jack
iMONITOR
MACOMB, MI.
#17
Nothing else has been changed other than updating the firmware? Is your signal level the same as it was before?
it sound the same plus I have adjusted the digital settings what do u have urs set on mine is on 8
Everybody's digital settings will be the same, each situation is different. Have you tried the defaults? Maybe with the new firmware that's all you need.
nj
#18
Iv tried the new firmware and sounds horrible
