HP-1: Firmware Question
worble7
Fremont, Ca
ok maybe my firmware is not right on my hp1 it shows firmware version 2.05 could this be right I did the update and that's 2.6 the database version is 02/01/2015 this part seems fine maybe that's why its not working so right??
also can someone tell me how to load older version back on to this just in case I want to try them. thanks in advance for your help. Jeff
worble7
Fremont, Ca
no one knows how to do this?? should homepatrol sentinel be loading V2_06_08.scn or something close to this firmware? thanks again
UPMan
In Memoriam
Arlington, TX
2.05.03 is the latest released firmware. You can manually load firmware by putting the "bin" file in the scanner's firmware directory then restarting the scanner.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
On your computer: C:/ProgramData/Uniden/HomePatrol_Sentinel/Updater/
On the flash drive: HomePatrol/firmware/
