SDS100/SDS200: Firmware Release 1.07.00-1.07.04 Main / 1.02.00 Sub
bravo14
Polk County FL
Thanks for the reply. I wasn't too sure if someone does that for you. By the way I did a search test on the filter on Auto it slows the search slow which is good I'm doing Normal seems running good.
nessnet
Eastside of Lake WA
BTW, once you do the (via Sentinel) firmware upgrade, if I'm not mistaken, it should be in the firmware directory on your radio/SD card.
teknishun
Alvin, Texas
I updated the Sentinel and updated the Firmware too for the SDS100. On the printed instructions for the
firmware it mentions "HPF" in relation to filters. What is "HPF" and what does it do? The options given
are auto, normal and inverted.
I assume it means High Pass Filter but I am not a mind reader.
belvdr
No longer interested in living
It means high pass filter. They updated the release notes.
nessnet
Eastside of Lake WA
OK, I know what a high pass filter is - at least in the audio world.
It lets high frequencies pass - and filters/cuts low frequencies.
I just enabled global auto filter - normal.
Hooked up to external speaker - and I still hear that low rumbling during transmissions.
Tried inverted, still the same.
Paul, please elaborate on exactly what this "HPA" does please?
KevinC
Other
Super Moderator
Home
I would suspect it's a RF filter, not an AF filter...but I could be wrong.
mule1075
Washington Pennsylvania
Since it says adds additional countermeasures to help in strong signal areas. I am guessing you are correct. I am testing it now and it seems to have eliminated my adjacent channel interference. But more testing is needed.
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
Double-checked and confirmed that the release notes say "RF High Pass Filter (HPF) "
So what does this mean specifically? What are the high pass settings? What exactly is occurring here when enabling?
What specific use cases will it be appropriate to enable this? (i.e., to reduce cellular interference? UTMA/PCS/LTE interference?)
trentbob
W3BUX- Bucks County, PA
On the global options there is a choice of "original"... I'm thinking that means that choice is as if you didn't do the update?
trentbob
Yeah it makes sense I just didn't see it referred to in any of the descriptions. It would also mean this is a new filter and not just more optional user control over an existing filter.
gillham
People's Republik of Massachusetts
Just some light reading about filters - because I was only really familiar with what a band pass filter is from ADS-B SDR..
Understanding the Basics of RF Filter | Electronics Notes
High & Low Pass LC RF Filter Design | Electronics Notes
So - for the high pass filter, how does the cut off frequency work on the SDS100?
Edit: Is it safe to assume that the 'inverted' option in effect turns it to a low pass filter?
If you choose to do Auto, does the scanner store which is ideal for that specific frequency, Normal or Inverted, once it receives a transmission so that the scan rate speeds up even after a power cycle?
werinshades
Chicago , IL
I would hope this is added to a future Sentinel version as an option. Currently using this as my Global setting, but any updates via Sentinel it reverts back to 1 of the 3 other options and excludes "original" I have to go into Settings each time I update and manually change it back to Original.
u2brent
OAMPT
KRWDPAXKRS1
Could someone shed some light on what this "Original" setting is? As opposed to the other settings in Sentinel? :unsure:
Why is it not in Sentinel? :confused:
Does it mean the filter is not even utilized? And that prior to this FW it was not even used? But the filter was there??
Ugh, my head is spinning..
