Firmware TK-7185-E and TK-7180-E
PISBUS
Hello, my name is Aitor, and I would like to know if someone can send me the firmware for the TK-7185-E and TK-7180-E. Thank you very much.
PISBUS
Hello, I'll tell you a bit about these transmitters. I acquired two second-hand TK-7185-E transmitters to create a project to send data through the external serial port (COM2) and receive it on the other transmitter. The data is a GPS nmea frame. But with the original firmware of the TK7185 I got nothing, I spoke with a technical service and he told me that he barely knew that station but if the TK-7180 and possibly installing the firmware of the 7180 I could make it work, so yes I located the firmware of the 7180 but version K and installed it and now I see that I receive something but the maximum baud rate is 2400 and in principle that is not worth it, so I want to put the original firmware back (Which I do not have) and do tests with the speed that I discovered that if you enter another communication speed it does not work, so I want to try but I cannot locate the firmware of the TK7185E, and I would also like to try with the firmware of the TK7180E since the one I have is TK7180K and the frequencies do not match. And let's see if there's someone kind enough to pass them on to me, especially the one for the TK7185E or TK7185K in the worst case. Thank´s.
The Kenwood firmware for the North American market radios is not frequency specific. It's the same file for a TK-7180, 8180, 2180 or 3180. I'm not sure how that'll match up with the 7185E.
I don't have any European market firmware or manuals, though.
Looking at the in-depth manual for the TK-x180 radios and it's info on connecting data devices, like the KDS-100 data terminal, it only allows 1200 or 2400 bps.
AM909
Radio/computer geek
SoCal
... which makes sense, given that we're talking about analog radios. [add] Max data rate it's designed for is probably the Fleetsync "high speed" at 2400 bps.
PISBUS
Hi, thanks for the replies, I'm hoping anyone has the firmware for the TK7185E. I've already received the firmware for the TK7180E.
