First Energy
TheLeaper
WB2HKK
Old Bridge, NJ
I just got a Bearcat BCD996P2. I'm using Scancat-Lite for programming. So far, everything is working great EXCEPT for the First Energy system.
I've double-checked the it IS in the scanner correctly, but I hear nothing. I programmed ALL the NJ 900Mhz frequencies, and the NJ talkgroups. The discone antenna is on my 45' ham tower, and I hear the Matawan and Upper Freehold sites very well. When I listened on the old system years ago, there was always traffic on the system.
TheLeaper
WB2HKK
Old Bridge, NJ
I've double-checked that it IS in the scanner correctly, but I hear nothing. I programmed ALL the NJ 900Mhz frequencies, and the NJ talkgroups. The discone antenna is on my 45' ham tower, and I hear the Matawan and Upper Freehold sites very well. When I listened on the old system years ago, there was always traffic on the system.
UPDATE: I also have a Raspberry Pi running OP25 to scan the system. It DOES hear some traffic on the Matawan system ( 938.7125 control ) , and reports a system ID of ' 0x89a '. The Bearcat shows a system ID of ' 089Ah ', and hears nothing during the same transmission??
W2MB
Washington Boro NJ
I've got the same issue here in central Warren County. Three of their sites are within hearing distance and I receive nothing since their system upgrade. I've tried to get better info on the new system but haven't had any luck so far. Hopefully, some of the whiz kids here can eventually figure it out!
TheLeaper
WB2HKK
Old Bridge, NJ
I programmed the 3 Matawan frequencies ( not the control channel ) as a conventional system. When I scan those as conventional, I DO hear dispatch, but NOT the trucks. So I guess the scanner does NOT understand the control channel for some reason? Is this some sort of ' custom ' P25 system? Anyone else able to monitor the system with better equipment and decipher what is going on?
TheLeaper
WB2HKK
Old Bridge, NJ
UPDATE: I've programmed 3 frequencies from MATAWAN, and 2 from UPPER FREEHOLD as a CONVENTIONAL system. I did not program the control frequencies. I can now heard everything. No talkgroups, but at least I can monitor the system. If I program First Energy as a P25 Phase 1 from the database, I hear nothing.
W2SJW
Senior Member
Moderator
Northwest NJ
I know this system works properly on a 436 & SDS100, as my friend was streaming the system during one of the big snowstorms this past winter until the storm passed.
danlewis
I regularly hear First Energy in the Matawan area, both dispatch and field, on the 900 MHz system. TG 3311 is very active. I'm using a PSR-500.
