Generally, yes. You must be authorized by the agency or company holding the license under which "dispatch" or "another fireman" operates in order to transmit on their frequencies and you must transmit with equipment certificated by the FCC for use on those frequencies. Amateur radio equipment is generally not certificated for use outside the amateur radio bands.So if i wanted to call dispatch or another fireman would that be illegal?
Show me where the second part of of that is stated in Part 97.You need a lisence to operate any ham radio which will allow you to operate any radio in the event of a national emergency.
W9BU hit the nail on the head.
I would also add that under part 97, you cannot use amateur radio in any activity in which you have a "pecuniary interest". In essence, if you're getting paid to do what your doing, you can't use ham radio to facilitate it. (This is to prevent ham radio from becoming another business band.)
We've beaten that horse many times, so let's not do it again.Show me where the second part of of that is stated in Part 97.
A license is always required to transmit under Part 97 rules. There are no exceptions....a license would still be needed to use an amateur radio on an amateur band.
The FCC does not license radios, but they do grant certificates indicating that a particular radio model is accepted under various parts of the FCC rules that require those certifications.Under Part-90 a 'civilian' can operate a Part-90 licensed radio in an emergency, or if he is ordered to do so by one of the employees operating that radio system.
Do first responders need a FCC license for a ham radio to transmit. So if i wanted to call dispatch or another fireman would that be illegal?
If you are going to speculate about what Part 97 says without bothering to look it up yourself, you really aren't contributing to the conversation.I can't cite the paragraph or line, but it's covered under 'emergency' operations.
I underlined the key point because so many folks misinterpret what 97.403 says:97.403 Safety of life and protection of property.
No provision of these rules prevents the use by an amateur station of any means of radiocommunication at its disposal to provide essential communication needs in connection with the immediate safety of human life and immediate protection of property when normal communication systems are not available.
