FleetNet Zone 2 Demorestville Tower
Guccisock5
Located in west end of Trenton, using HP2 with SRH 789 antenna. I've had intermittent issues getting consistent reception from this tower for years. Sometimes its great, sometimes it's trash.
Has anyone else had issues here? Perhaps I'm just in a bad spot with not enough antenna elevation.
Mainly scanning for OPP.
gary123
I have seen several sites with bad antennas. Check the signal strength also monitor EMS for noisy signals in certain areas. This will come and go.
Guccisock5
So, it turns out to be an issue on my end with interference from laptop I'm using for feed.
Update: it's actually when my audio cable is plugged into headphone jack to line in on laptop.
When unplugged, everything is coming in crystal clear, nothing missed. Seems only P25 affected.
Very strange. Posted in Uniden Tech Support but haven't had much help. I figured I'd reach out in here 😊
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I hope you can resolve your issue, however cross-posting same content in different forums is discouraged.
I will re-direct replies from this thread to your other thread which should get more eyes on it.
Everyone, if you can help please respond in the link below, thanks!
