Florida Power & Light
bravo14
#850Strong
I have programed the FPL on the psr500 and can't get nothing to pick up. I delete it and went on the software and download it from there. I'm still having the same problem. The systems I scanning do not have Control Channel I do hear the noise it makes when I Analyz it. The system would be Saint Augustine (047) and St John (52). I'm not sure if St Johns River is also the system here.
DonS
Franktown, CO
Did you enter the frequencies into two separate TSYS objects, one for each "site"?
Did you enter the frequencies in the "LCN" order listed on the RR DB page?
Did you set the two TSYS objects to "EDACS Narrow"?
bravo14
#850Strong
The Freq is in order LCN and Tsys objects and I have Edacs Narrow. I have my 996 scanning and the 500. I have the 500 on wildcard searching for TG's.
