FMP auto scan dosn't work.
#1
Hello everyone. Recently bought rtl-dsr and trying understand all these things in radio :) I wanted to ask since i didn't found answer by searching forum. The FMP tool, when I press S button on keyboard , doesn't scan anything for me and I'm getting error "FMP.ScanList not found" . I understand that I need some file with range of frequencies, right ? I would put it in to directory , but I don't know what format it should be , anyone here can help me with example ? :) Thanks guys!
Sorry for bad English , i'm from non English speaking country.
Greetings to everyone.
#2
Look for or create a file named: FMP.ScanList.txt
copied from the FMP.txt file:
scanning
FMP can (slowly) scan frequencies
a frequency list, one frequency per line, should be placed in a file
named FMP.ScanList
the format of each line is:
frequency mode description
example:
450.1250 TIII Acme Radio
frequency is in MHz
mode text controls bandpass filter selection
4 kHz modes:
D-STAR
DSTAR
IDAS
NX48
NEXEDGE48
7 kHz modes:
DMR
TRBO
Cap+
Con+
TIII
9.5 kHz modes:
NXDN
NEXEDGE
NEXEDGE96
NX96
P25
12.5 kHz modes
PV
ProVoice
any other text string (analog, LTR, ...)
blank lines in the file are ignored
processing of the FMP.ScanList file stops if a line containing
the string <EOF> is found; frequency entries that you don't want
to scan can be stored in the file after the <EOF> line
pressing S starts scanner mode
pressing Esc exits scanner mode
no other scanning commands (Hold, L/O, etc.) are presently implemented
FMP's scanner mode is designed to be used with DSD+. FMP and DSD+
should be running in the same folder. While DSD+ is decoding
digital voice, FMP will auto-hold on the current RF channel.
If DSD+ is not decoding digital voice, FMP will auto-scan to the
next channel in the scanlist. This behaviour will let you monitor
multiple digital channels, including control or rest channels.
FMP will not get hung up on constant carriers that are not broadcasting
digital voice calls.
EU
#4
sadakura, using notepad you should create your own FMP.ScanList file (.scanlist should be the file extension) and put it in you dsdplus folder (also fmp folder)
in that file you should put your frequencies in the format as described above:
that should do it, and fmp will see the frequencies in the scan file.
#5
That's great , Thanks , I have added few I know , but no success, later i have readed out that police here on TETRA, so it useless :).
Maybe a little bit "noob" question , but is there any way to scan DSD supported (decoding) frequencies automatically ? Let's say 160-170Mhz and stop on first decoded packets ? That would change world :))
I think it's truly possible, just question of automation/coding
Greetings,
Thomas.
EU
#6
You can try the tetra scanner project ... with some luck police is not encrypted.
I usually use sdr sharp to visually search for distinct looking DMR signals ... or you can do that from the fmp. ... yes it would be great to have a scanner for a specific modulation.
As for the FMP scanner ... my problem is that the scanner doesn't stop when voice packages are detected. Despite of reading many posts and checking everything twice I still haven't solved this
#7
Thanks for note , that tells that I'm not alone , I hope in future it will be definitely made, looking from point of software it would take an day of coding, just telling.., my friend familiar with this, however in completely different niche :)
riccom
SLIDELL, LA
#8
Is there a way to use it for analog and not have the white noise in the background?
Berkeley Co WV
#11
I am looking for it and do not see a command line for it
Read through this post - http://forums.radioreference.com/2667714-post5.html
It has -
Squelch logic has been added.
Use -q1 on the command line to enable squelch.
Press Q to enable/disable squelch.
This is for DSD+ version 2.18 which is the Fastlane version. If you don't subscribe to Fastlane then you must be using the latest public version which does not have the squelch function.
