Format 996
chrisnigro
Kansas City
Does anyone know how to format a 996. Just broke it out of the box and want to erase all the junk that it came with. I don't even know where half these places are - let alone will I ever monitor them.
Thanks!!
chrisnigro
Kansas City
Nevermind... I figured it out. It is the same process as my old 245 Hand held. Sorry for the post.
Initializing the Scanner’s Memory
Warning: This clears data you have entered. You cannot restore user programmed data that has been deleted. You can, at a last step, restore only the original factory data.
1. To initialize the scanner’s memory, turn off the scanner.
2. While pressing [2], [9], and [HOLD] at the same time, turn on power. At that point anything you have programmed is gone. You are given a last opportunity to keep the factory programmed data when you see the question: Restore Preprogram List? Yes=”E”/”No= ”.” If you do not say Yes, the scanner is totally empty.
