Fort Carson, Freq Help
wb0blv
Widefield, CO
I have attached my Setup, to try and receive FT Carsons Freq...
Can someone tell me if it set up Properly??
mpdonala
Colorado Springs
Yep it looks good with the RR data. But it won't work! There are several of us here in the Springs working on getting it working we just need some valuable freq's that we are closer to getting. we'll keep everybody up to date as we get info. Mark
scanner_nut
Confirmed Ft Carson Frequencies
I have been using my pro-96 to search for active frequencies between 410.000 & 420.000 mhz. Here is what I found so far of active frequencies associated with Ft. Carson:
410.900 - PD
410.550 - FD
410.1625 - ?
410.550 - PD
419.150 - range control
410.325 - PD
410.1625 - range control
410.325 - ?
410.700 - PD
410.150 - PD
Modulation was FM, but the scanner turned to dg when these channels were in use. I also have not had any luck with using win96 to program my scanner with the right base, offset and step values. If anyone knows how to setup the scanner to also display TG info while searching, please let me know.
Good hunting !
firescannerbob
Colorado
As Mark said, scanning Ft Carson is a challenge. I have a feeling thier system is "non-standard" in some manner...
wb0blv
Widefield, CO
Thanks for the Freq's
Thanks for the Freq's in the 410 area..
Sounds more like all Range Control. with the Different
Guards Policing the Impact area.. and tank trail down range.
Interesting any way..
Thanks..again
If I find any other interesting freq's will post'em..
Lee
