Fort Detrick Site Control Channel - Joint National Capital Region
troymail
Silent Key
I was having trouble listening to this system. I found that the control channel is currently: 385.950 MHz which currently isn't listed as a control channel in the database.
https://www.radioreference.com/apps/db/?sid=4699
(posted in wrong forum, should have been just in Maryland)
You can (should) submit an update - but for these systems and sites, based on the number of frequencies marked in RED, they should really all be treated as potential control channels.... some systems (vendors) are like that...
