Fort Madison Prison
WIscannerguy24
Waukesha, Wisconsin
Does anyone know what frequencies the Fort Madison Penitentiary uses. I looked in the 800mhz band and no control channel found. I assume they use conventional frequencies.
N0ZJT
Oelwein, Iowa
It looks like the state of Iowa has some repeater licenses in Fort Madison
453.375 - this one is commonly used at other facilities around the state.
460.125
460.275
Try these and post back here if you find anything so I can update the database.
burner50
The Third Variable
Moderator
NW Iowa
Heya egrams, I submitted a bunch of railroad frequencies and they havent come up? Is there more/different/better information that you need me to provide?
N0ZJT
Oelwein, Iowa
I haven't worked that submission yet, been really busy with work. Maybe over the weekend unless someone else beats me to it.
owenmcc1
Muscatine, Iowa
I have noticed that the Iowa Department of Homeland Security and Emergency Management has a 1300 MHz Licensed Frequency here at Muscatine. Not Sure what it would be for, as there is no State Penniteniary anywhere in Muscatine County. The closest is at Mount Pleasant, Fort Madison, and Anamosa.
IowaGuy1603
Jones County Iowa
Heard these last weekend:
453.375 (127.3 PL) - most active repeater
460.125 (141.3 PL) only heard briefly
453.375 is their main freq
They should have a secondary freq------somewhere in the 453.xxx area.
460.125........I am surprised you heard anything on that at all............It is a data link for the electronic fence monitor.
154.995 is the mobile radio frequency statewide for the DOC
ISP is NOT on a trunked system at this time.
