Franklin County Broadcast Feed Silent
Youngsville, NC
#1
Not sure what is going on in Franklin County but does anyone know of any changes they have made that would cause the broadcast feed to go silent? If I raise the volume it sounds like an open line noise or something but nothing is broadcasting. It has been silent since Monday.
I know in the past Franklin County has taken towers offline to work on them and that has caused the broadcast feed to go silent but it has never been for this long before.
Prior to Monday the transmissions were grabled and sounded like the deputies and dispatchers were under water. This happened before and they took towers offline, did repairs and everything was good again. Then it rained and the transmissions went back to garbled again. Now the broadcast has been silent since Monday.
Pam
Youngsville
