FRCC Niwot site is on the air.
scanlist
Scanning since the 70's to today.
Greeley, CO
Discovered this site was active last night. PRO96COM is detecting it as phase 2 though no phase 2 activity has been noted so far.
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 5AB
System Name : FRCC
WACN : BEE00
Tower Number (Decimal): 5-60
Tower Number (Hex) : T053C
Tower Description : NIWOT
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) : WQXV229
Timestamp : Fri Aug 12 06:05:56 2016
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-1178","i",769.36875,"01-1178",799.36875,0,1
"01-1218","v",769.61875,"01-1218",799.61875,0,17
"01-1282","a",770.01875,"01-1282",800.01875,0,0
"01-1322","a",770.26875,"01-1322",800.26875,1,0
"01-1442","a",771.01875,"01-1442",801.01875,1,0
"01-1482","c",771.26875,"01-1482",801.26875,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
522,"T0516",5ab,"01-1758",772.99375,"Adams 700 Simulcast"
530,"T051E",5ab,"00-0369",853.31250,"Weld Simulcast"
555,"T0537",5ab,"01-1826",773.41875,"Weld S.W. Simulcast"
ScannerSK
Weld County, Colorado
I was unaware that tower 555 was "Weld S.W. Simulcast". I was under the assumption this was a single tower and not part of a simulcast system.
Currently, RadioReference has it simply labeled as Fort Lupton.
Shawn
scanlist
Greeley, CO
It's been a 2 site simulcast configuration for awhile now. One tower is at the Southwest substation in Del Camino/Firestone the other at the Fort Lupton substation.
This replaced the single site that was on the old broadcast tower East of Dacono.
Fort Lupton had poor coverage issues with the single site after the split from DTRS.
Spitfire8520
I might be completely clueless! =)
Colorado
Shawn
There was a minor discussion when it first started at http://forums.radioreference.com/co...07113-frcc-tri-town-now-2-site-simulcast.html. It ultimately didn't really change much of anything. Everything pretty much remained the same except for the modulation type and some coverage pattern changes.
I personally have it labelled as "Tri-Area Simulcast" since that is what the Fort Lupton site was known as.
