Freescan hold-bandwidth?
#1
There is a "hold" dropdown in the site setup tag that has bandwidth options of AUTO/FM/NFM
I manually set this according to my modulation scheme, but I'm not sure how modulation relates to a timing/hold issue?
This seems a bit different from the hold-time setting, so it has me a bit perplexed. :)
mdulrich
Van Wert, Ohio
#2
Make sure you are running the latest version, 2.08. Mine shows Hold Time as having 0-255 options and Modulation showing what you describe.
Mike
#3
Got it! I might be having some sort of video card issue as the button descriptors are skewed to the right - but got the actual function sorted now - thanks - I did need to upgrade..
