Freescan question.
Placid1
NM
If I use freescan to program my scanner (bcd996xt) will it erase everything already on the scanner or will it just add to what is already there?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Depends on what you tell it to do when you upload. See this image from the user guide;
File:FS upload queued v8.JPG - The RadioReference Wiki
In general, when you get a new DMA radio, it's wisest to dump the pre-programmed contents first, then save them away. Then when you are ready to start your own programming, use the 'Erase All Systems and Settings' button for your first attempt. Thereafter, you can decide whether to replace or add...best regards..Mike
b7spectra
EMS Dispatcher
Cobb County, GA
When ever I go to upload a new "code plug" to my 396XT, I always save it to my laptop with the date in the file name, that way if I want to go back to a previous code plug, I have it on file.
