FREESCAN STEP and MOD
ScanMaine
Was MaineRadioMan
Dresden Maine
#1
Does it really work with setting the steps and the mode to the scanner and if so where is the most accurate Step and mode chart. I know all two ways must be 12.5 NFM but does it matter on a scanner or just leave it at auto!
Anne Arundel County, MD
#4
Each of those 3 ranges have different default steps. In fact there are at least a couple different default steps just between 150 to 175mz.
536/436/HP1/HP2/996XT/996P2/396XT/325P2/PSR800
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#5
Narrowbanding would have no effect on your loband stuff, so auto would likely work fine. However on the VHF and UHF ranges, in some cases, narrowbanding would change the step and what mod(ulation) you would need to set.
For example, amateur radio frequencies, GMRS, FRS and the like are not impacted, so auto would also work fine.
This also depends on which scanner you are trying to program? Mike
ScanMaine
Was MaineRadioMan
Dresden Maine
#6
im asking for help
BCT15x and and 536hp and where can I find the current or correct band plan. I didn't think it would make a difference on the scanner so That's why I was asking for help
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#7
I wouldn't worry about a 'bandplan' - concentrate on your intended targets and see whether they've converted over. Since your town is in Oxford county, this is what the database shows...
Oxford County, Maine (ME) Scanner Frequencies and Radio Frequency Reference
You do have some narrowbanding here - anything marked 'FMN' in the mode. Looks like they didn't adjust for the new channel spacing, so you can leave that as the default.
Are you intending to search these ranges? You would have a devil of a time with the different spacing depending on the service being searched...
Mike
ScanMaine
Was MaineRadioMan
Dresden Maine
#8
Mike
Thanks Sir, so in other words dont worry about it. TY
#9
Band plan and default frequency steps are two totally unrelated things.
Still trying to figure out exactly what you are asking or trying to do.
ScanMaine
Was MaineRadioMan
Dresden Maine
#10
when you open up FREE SCAN it says STEP and MOD, What does that mean!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#11
Actually when you open a group up in FreeScan, those are 2 columns you will see, and if you're talking about a conventional group, the user guide has it defined...
Freescan Create Group - The RadioReference Wiki
Mod is the operating mode (maybe FMN in some cases), and Step is the spacing between channels (for VHF narrowband, I believe that's 7.5 khz)
To help you along, you can see the list of exempted services in the FAQ section of;
Narrowbanding - The RadioReference Wiki
from our glossary...Mike
ScanMaine
Was MaineRadioMan
Dresden Maine
#12
Thanks I will do some reading tomorrow when i get back in the COM COM! Thanks again!
