Freezing rain event here today in Michigan. About 1/4" to 3/8" accumulations on flat surfaces. The wire antennas are fully encrusted and sagging but have held up. Fortunately the air is calm, absolutely no wind. OAT is hovering right at the freezing mark, however, the insulation is all black or dark grey which makes it easier to absorb whatever solar radiation is available. In fact, the wire antennas have started to shed ice even though the air temp is right at freezing. The aluminum antennas (discone, TV, J-pole, vertical) are still ice covered. Antenna wire is #18 PolyStealth or #12 THHN solid. Antenna support lines are good quality poly or nylon 1/8" or 3/16" diameter.
