Freqs downloaded from RR to pro 197
mriley7212
I just received a Pro 197 as a gift today. I have the software (ARC 500) and downloaded 12 Trunc systems to the new scanner. I can hear the conventional channels but none of the trunc's are showing up. My Pro 96 had no problem with them.
Any suggestions?
Mike
Highpockets
New Jersey
Any suggestions?
Mike
Were the trunked systems assigned a scan list and are those lists enabled so they will be scanned.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Mike, zip and attach the gr5 file. I'll have a look. Though as Steve indicated, it may be SL assignement and enabled.
mriley7212
Pro 197 problems.
I think I have done what you have suggested. can you explain what you were thinking?
Thanks,
Mike
fmon
Eclipse, Virginia
Thanks,
Mike
look at numbers under Scanlist in Talkgroup section. Do all have a -1 -2 etc? If so, simply press a number to toggle list ON/OFF. for upper list (10 through 20) press FUNC plus #. to toggle ON/OFF.
