Freqs for Adam's county area State Police Disp?
cowboywildbill
Does any one know which freqs are used for that area around Gettysburg and toward the Md. line. Mainly a Dispatch and a tact channel and also which talk around they use.
I looked at the data base but I wasn't sure which cannels were for what areas. Thanks
ChrisRupert
Clinton County, PA
PSP Channel B which is 155.670 base and 155.910 mobile with the PL listed above of 186.2 Hz.
I am not sure, however, this area may now be using OPENSKY primarily.
K3ONW
GETTYSBURG, PA
the correct info is:
PSP BASE 155.580
PSP MOBILE 154.950
PSP MOBILE-MOBILE 154.755
PSP TAC-1 155.460
PSP TAC-2 151.490
ALL FREQS USE PL 186.2
