frequencies flipping
snapperq
Tiffin, ohio
I have a new Unide BCD996XT. When it stops on a frequency it displays another frequency and displays it back and forth. Is this normal?
ChrisP
Portland, OR
Are you monitoring a trunked system? If so then the scanner displays the control channel frequency while waiting for a talk-group to become active, then displays the voice channel frequency when there is an active voice channel.
That might be what you are seeing, but a little more information is needed...
- Chris
snapperq
Tiffin, ohio
- Chris
This happens on all frequencies all the time. It doesn't matter what freq it is.
dxradio2003
Frequency display
Hi,
This is normal if you are listening to a trunked system. My radio alternates between the control channel frequency and the talkgroups actual frequency in use at that moment.
If you listening to a conventional channel or something other than a trunked system, then maybe the priority is set to on.
Either way, I hope this helps.
Thx
kma371
Wirelessly posted (iPhone 3GS: Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_3_1 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8G4 Safari/6533.18.5)
MOde 1, mode 2, and mode 3 make the display, display different things.
Mode 3 is a better settting for you it seems. It will only show the talkgroup ID and doesn't flash back and forth
Mode 2 flashes between the radio ID and the trunked talkgroup IIRC.
