Why is my scanner not scanning? It will only change channels manually even after I push the scan button. I don't have the manual....I forget if there is a trick to start the scanning. Anyone know?
<sigh> As if my earlier post didn't bump it to the top.
I looked for my manual and it is still packed in some unpacked box from the move. So the only thing I can say is check to see that you don't have the slots locked out. Obviously it will not scan a L/O channel. Also make sure and review each of the programmed channels to make sure they are valid. The way mine is set up I cannot easily look at the back, but isn't there a "reset" on the rear, that & reprogramming may be your next step. There is no secret to getting it to scan, other than having valid frequencies in at least two of the 16 slots.
