Frequencies for SBSO
Confused1234
Mandeville, LA
In the Louisiana Wireless Information Network (LWIN) system I see the talk groups for St Bernard parish Sheriff, but I don't see the control frequencies. Does anyone know what frequencies to use?
INDY72
Indianapolis, IN
You must program in the frequencies for the sites you are nearest, or will be monitoring..
Confused1234
Mandeville, LA
Which sites.....
The problem is I travel 1 hr to work, this is between two differant sites. How do I program the system in a 396xt?
loumaag
Silent Key - Aug 2014
Katy, TX
If it is an XT, program both sites (or even more) in the system. You can either put them both on the same SQK or on different SQKs so you can manually change them, assuming you are not using GPS control.
