Frequency Question
Maine
I got a frequency list from a local department and have a question on the RX PL and TX PL... One of the channels has D411 under RX PL and TX PL and another channel has D606 under RX PL and TX PL.
The software allows me to input for example "203.5" under RX and TX PL's, but what does D411 and D606 mean and how do I program that?
Any help would be greatly appreciated! Thanks
racingfan360
D411 and D606 represent DCS - Digital Coded squelch (or DPL - digital private line) codes. This technique uses a binary bit steam encoded in the signal and not just a sub-audible tone used in CTCSS/PL.
If your radio/software supports DCS/DPL, then you should see a list of codes to use - typically starting D023N in the pull down list after the 250.3Hz PL tone. You haven't said what or how you're trying to program.
Setting no tone on the Rx and Tx frequencies will allow you to hear all traffic on that channel, irrespective of what PL/DPL tone is being used.
8859
Maine
Thanks for your help. I am programming a Kenwood TK 280 with software KPG49D.
I added the D606 and it converted to "D606N". After writing to radio i was able to key up the tower and hear dispatch clearly, so I'm assuming it worked.
N2AL
Tennessee
On the Kenwood software when you are using a digital code squelch (DCS) tone, after you select D606 for example, it will show in the programming software as D606N. That is normal. Sounds like you got it working okay, good job.
Sent from my iPad using Tapatalk
