Frescan porked P25 system programming
maus92
OCMD
Freescan seems to have porked my prgramming for true P25 systems in my 396T. The scanner is looking for a CC on the USNA 380 site - the CC frequencies are programmed in and the radio receives a signal on the main CC - just no tracking and no decoding.
Is their a band plan setting that I am missing? Currently there are no values in those fields.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Maus-
Did you try checking the System Type? I recently had a similar problem when I had selected the wrong system type, and my 396T wouldn't track, even though it was receiving the control channel.
maus92
OCMD
Freescan imported it from the scanner and set it for P25 Standard (XT) - are you saying it should be MOT Type II/P25?
lebrunmn
Yes. That's the setting I'm using, and I copy that system fine. I think the other system type setting is for 396XT models. I'm using a 396T.
Hope that helps.
