FRS crosslink to zello
poncho524
I'm looking into setting up a crosslink between frs and zello. I'm getting confused over the connectors for the radios.
Midland uses a 2-pin connector (S5 I think) and Motorola uses a 2.5mm combined connector. I'm not sure if either of these has a standard way of patching over to a common TRRS w audio and mic.
Does anyone have experience with this setup and have tips? Is there a radio w a standard TRRS connector that can directly patch over?
a417
more details, midland and moto each make more than one radio. Model numbers help.
poncho524
Just the inexpensive handhelds. I don't have one yet... Looking to get what works best for the setup. Motorola talkabouts have the single 2.5mm jack, while midlands have the 2 pin.
JeremyG760
Oceanside, CA
I've been able to make this work with a CCR previously. I purchased an APRS cable that has the 2 pin K connector on one end and a TRRS on the other. I then turned on Vox in Zello running on an old Android phone I had laying around, as well as on the radio. It isn't perfect, but it did work. Do expect there to be small delays and cutoffs at the start of transmissions as vox activates.
ETA: I don't know of a cable like this specifically for Midland or Motorola, but you could probably kludge one together. I do know you can find "better" (fancier) solutions on eBay by searching for Zello Crosslink or Zello Gateway, but I don't have experience with those.
Spankymedic7
Wisconsin
I haven't used FRS in quite some time; however, I'm pretty sure the FCC would frown on this from a legality standpoint. I don't believe that linking in FRS is allowed.
shawn1899
I say do it... even if talking on the zello app, you are still using a 2 watt frs radio as the donor. That means even when talking through zello and when it comes out on donor radio, it's still on the 2 watt limit and all. Honestly the only way someone would even know or care that you're doing it is if you tell them... if the govt can breaks rules every day and lie to our faces, then you should be able to also.... (I know I will catch **** for that one from the Karens).
