I think I've isolated the problem to the external fan on the heat pump unit....or it's at least 1 potential cause. The radio ran fine for several hours tonight. It then experienced the hum during transmit. It seemed to coincide with the external heat pump kicking on. I'll need to explore this more. It was only momentarily though (60 seconds) tonight and then it was gone. It wasn't for a prolonged period of time like the other night. I also didn't pay much attention to external causes the other night since it did it from the get go. Nonetheless it was clearly heard during the conversation I was having tonight. I'm not sure if it's the only cause or one of many that the radios susceptible to. Presuming that it is indeed external, and not some intermittent internal issue, is it likely interference coming in on the AC line or external RF? If it is the AC line would a ferrite bead be of any help or something like the Isobar Tripp Lite to isolate the radio enough to potentially reduce it? Any and all solutions would be greatly appreciated.
Tripp Lite ISOBAR8ULTRA Isobar 8 Outlet Surge Protector Power Strip, 12ft Cord, Right-Angle Plug, Metal Lifetime Limited Warranty & Dollar 50,000 Insurance White
https://www.amazon.com/dp/B0000511U...t_i_62ZJDQRHJW8S9ZBJ5VA3?_encoding=UTF8&psc=1
