- Joined
- Aug 9, 2019
- Messages
- 39
- Reaction score
- 10
Noob here, but i'm slowly catching on.
I want to scan the Air band but start at 118.00 not 108.00.
I am using the RT software for programming. Under the Limit Memories tab I've put in my Lower and Upper limits in L1 and U1.
This is where things grind to a halt.
I thought that if I then went to the Air band and started to Scan the radio would only scan from the LL to UL but i'm getting a scan starting at 108.0 still.
When I select: FWM -> MR, then use the dial to scroll through the channels in Memory, my Lower and Upper limit/freq's are in there, but i dont know what i need to do to scan between them.
Thanks in advance for any guidance.
cheers, MD
cheers, MD
