herksen
I am afraid that I blew up the EXT DC IN port of my FT3D.
Most probably overvoltage.
Other than that, the HT works perfectly well, it only doesn't change anymore via that external power connector
I'm looking for a solution, which can be:
-a repairservice
or
-a service manual (anyone? where can I get one)
There is another question:
If you remove the battery from the FT3D, you see the metal backplate with 3 copper-colored contacts, a white label with SN# .... and
a rubber cap.
I removed it (very easy), and what you see is a hole, thru which you can see a SMS part (could be a resistor??)
What is this for??
Anyone??
Thanks for reading, and 73 de Robbert / PA3BKL
de Robbert / TA2IX (aka PA3BKL)
-a repairservice
or
a rubber cap.
What is this for??
Anyone??
