From what I can tell, the newer cables no longer use the FTDI chip. I've had a few emails about upload issues from PSREdit500 failing at 99%. And The error message also indicates the change in the cables. In PSREdit500, use these settings:
Under the Configuration Menu, select the Serial Port Settings. On the screen that appears, select the COM Port option, and then at the bottom of the page, check the option to add extra delay while uploading to the radio. You'll need to determine the correct COM port to use.
Mike
