Fuse size
taurus
I've purchased and am getting ready to install a Kenwood TK 730(G) radio in my vehicle. Can someone tell me what size fuse this particular radio should be protected with in the 12v lead?
SAR923
I've used 10 amp fuses in the past with no problem. I'm not sure what Kenwood calls for but either 5 or 10 amps is pretty standard.
kingpin
Trailer Park Supervisor
Seattle, WA
The 110 watt model comes with a 30 amp fuse so If you have the 110 watt one, go with that. If it's just the 50 watt, go with the 15. You'll be fine.
taurus
Thanks for the info guys. Its the 45w model so I'll go with the 15 and see if that does okay.
nhp9943
Kenwood Install Manual Spec's
15 AMP for 45 Watt
25 Amp for 110 Watt
You must fuse the ground wire also, no exceptions.
